Input/timer bar cant be turned off SONY KD49XG8305
Molyslip44
I'm sorry to raise this subject again but it's driving me mad. Lots of help and advice available but the options aren't available on my TV or I haven't found them!
  • Press the [HOME] button on the remote control
  • Scroll down to 'Settings' and press [OK]
  • Select 'Channel Setup' and press [OK] Option not displayed
  • Scroll down to 'Info banner' and press [OK] Option not displayed
  • Select 'Off' and press [OK[
  • Then return out of everything
Is there another option that may be hidden elsewhere?
35 REPLIES 35
Molysony
Hi
Thanks for the detailed info. Unfortunately, my set up with underfloor cabling and distance from TV
to main wiring hub inputs make this workaround difficult for me. My technical ability to make the changes would also be stretched. Your prompt response appreciated though.
Wish the same could be said of SONY technical support for an obviously well-documented problem.
CosmicCat
Sony have just released firmware update v6.7165 with a fix for this problem. I haven't been brave enough to install it yet. Think I'd rather wait for the dust to settle. Good luck.
Molysony
Hi
Thanks so much for the update. I share your reservations... It might solve the time-bar issue but unload another that will take 5 months to resolve. I'll follow the community to see if the update is stable and works.
G
Molysony
Hi
Just checked and the newer firmware update hasn't arrived on my TV. The wait for a solution continues. If SONY thinks it fixes a problem for a range of TVs surely it should arrive on those models ASAP?
CosmicCat
I believe the automatic updates are pushed out to tvs in a staggered fashion. Presumably so as not to overwhelm Sony servers? If you want the update immediately you can download and install it manually via USB.
https://www.sony.co.uk/electronics/support/software/00262498
HannahEd01
Community Team
Hi Molysony, with new firmware updates it takes time to be available over the air. And in some cases the larger updates might not even be available for over the air download. You can use the manual update as CosmicCat  suggested. Or wait for a while to get the automatic update.
