internal keyboard not displaying KD-55XE8396 - android tv
morph78
Hi
Has anyone experienced same issue that the internal android keyboard will not open. I have tried to change the setting system preferences without success, seems to developed fault since the last update. Thanks
Marino.Manolo
Genius
If you have an external keyboard connected, try removing the USB receiver.
Manolo
morph78
Hi
Thanks for the reply, no I have never had an external keyboard attached, but just took out a usb receiver for a mouse and that has fixed the problem. Thanks a lot for your help, as i was getting no where with it!
