IR Balster on kd 43xf8596
profile.country.IE.title
josh2019
When trying to configure the IR blaster  usung the initial setup wizard on  kd 43xf8596, I get the message An error has occured. Please try again later.
Pascale_F
Moderator
Hi Josh,
I'm just going to try to find this out for you, but in the meantime, maybe someone else in the community might be able to assist.
Thanks,
Pascale
josh2019
correction the model is 8796
Vanilla_
Hi josh2019,
I believe this could be a connectivity problem. Make sure you're setting up everything correctly. You'll find a full Guide on this setup here: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-43xf8796/artic...
Let us know if you still face the same problem.
Cheers,
Vanilla
