The message you are trying to access is permanently deleted.
I have a Sony Bravia KD-48A9 currently running the itv hub. How do I get the new version of
itv x ?
Hi @ian87bailey
As far as I am aware, ITV have not released it on Sony TVs yet. Your guess will be as good as anybody on here, sometime is 2023 is the best guess.
There have been several posts on the subject, for example
https://community.sony.co.uk/t5/android-tv/itv-hub-x/m-p/3895515#M60642
Hey @ian87bailey, as far as I'm aware, Sony postponed the launch of ITVX to Jan 2023, so it should be available during this month.
Appears to be problems and chaos right across the board with ITVX, my friend has a Hisense, the app itself has been updated to what is now called ITVX, but the icon of the app is still the ITV Hub app icon, when you open it, it loads shows all there is to watch etc, however when my friend tries to watch something, it shows a couple of adverts, then when the show is about to start its just a blue screen, nothing else. And that is after the initial deletion of her itvhub account and locked out of the app by some unknown pin, let me tell you, theres no uninstall feature either, so it took some sorting out which was only solved by resetting the tv itself and setting up a whole new ITVX account, but then as stated, blue screen when she tries to watch stuff on it. IMHO, hub still works fine on sony, i wont be in a rush to update it looking at the Hisense issues, maybe all of this is why Sony have rightly delayed it all to try and sort the problems out first. Well done ITV, shows what complete Plebs they are, its not like they havent had long enough to perfect the transition.
