Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
hi
if i want to go to other region for example asia,can i update my tv to new region firmware?
@mohsen124 wrote:
hi
Hi there
You will need to contact Sony support to confirm this - but it is my understanding that as long as the firmware version is higher than the one currently installed, then the TV will install it. (but dont quote me on that for other geographical regions)
I have just bought my brand new Sony KD-49x8305c.
Taken it out of the box connected to the internet via the network cable and attempted to do the software update.
It has downloaded the data, showing 99% complete. Has sat at 99% complete for over two hours without doing anything.
Looks like it has crashed, but I dont want to turn it off in case it messes soemthing up.
Is this normal, or do I need to call the shop?
Hi @robsonyrob
You might need to pull the plug to be honest, if it hasnt worked by the time you read this. If not, please reply back and ill private message you with some instructions.
Yep,
I pressed the 'back' button, then unplugged the TV and started again.
It is now downloading the update all over again. Think Im going to leave it riunning overnight and hope it is all sorted in the morning (maybe I'm dreaming)
Please feel free to message me I will try anything to get it going but not going to touch it till the morning, had enough of this right now.
