KD-49X8305C Software update crash 64%
grayhm63
Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
129 REPLIES 129
mustasi
Model: KD-49X8305C
And thank you @Quinnicus very much for your support!
mustasi
Hi @mustasi
Ive sent you a private message with some instructions - let me know how you get on.
Cathryn18
Hey,
I am having the same problem. Product number is kD-49X8305C
Would really appreciate the help! Many thanks.
Hi @Cathryn18
Ive sent you a private message with some instructions.  Let me know how you get on.
louisjenvey98
Hi Quinnicus,
Am having the same issue on a Sony Bravia 4k 2015 - 55". I would be most grateful if you could send me the instructions on how to resolve.
JungleJuice
@Anonymous Hi do you mind forwarding me your instuctions?
I have a Sony KDL 50W800C which is stuck in a reboot loop.
Many thanks
Aidanjc
My TV has not worked for days and days now.  The update seems locked.  UK support is open tomorrow.  Should I wait and phone them or is using the update via the USB worth doing?  Really annoying as I want to watch the Ireland ladies in the hockey final this afternoon.  Couldn't see the semi yesterday.  Any help appreciated !
profile.country.PL.title
Georgianix
Hi i am new here and I have a problem with KD-55X8509C. After firmware update there is no standby, no reaction on remote control black screen, starts reading USB (5 blinks on pendrive) and nothing more. Any Sugestions please.
Best regards
Gregory
Rcecil88
Could someone please help me with this as well? I have a MacBook and someone suggested using a usb a to a cable and doing an update or fast reboot using android sdk on my MacBook. If anyone could help it would be much appreciated,thanks!
