Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
Hello,
I had the same problem when I tried to upload the firmware through Wi-Fi. So I downloaden the firmware on a USB stick. When I plug the USB in mijn KDx8305c it almost immediatle restarts the tv?
Do you have a solution for this problem to @Anonymous?
Thanks you mate. Problem solved!
@Anonymous My tv model is 49x8005c and I am having the same problem, any tips/ hints/ helps please
Thank you in advance.
--Nish
@Anonymous Thanks for the fix, it worked !
I did tht. Thanks.
Hi I have a Sony KD-55X9305C Have downloaded the Youview FW V2623 onto a new usb stick. This was downloaded zipped can i use this ?.I understand I have to turn TV power off and put usd stick into a usb port , is there any particular one ? then switch on tv.
Can you please advise on a step by step instructions. regards Ralph53
I Also have the KD49x8305c and always crash at 74% could you please send me the fix!
