KD-49XF9005 Dolby Vision
Timelordsboots
Hello,
I have the above Model Sony Bravia TV which is great. However does anyone know if you can turn off Dolby Vision?
I use my Netflix through my Xbox and when you open the app it automatically switches to Dolby Vision so Non Dolby Vision shows/movies look washed out. I am unable to do this on Xbox and I was wondering any of you know a way to resolve this?
My parents have a later Bravia model that does seem to allow you to do this.
Many thanks
Jon
rooobb
You cannot disable dolby vision on the tv, you have to change the source https://www.windowscentral.com/xbox-one-enable-dolby-vision?amp
Normally though the app on xbox should recognize that the content is not dolby vision and do not send the corresponding signal to the tv... and btw I do not get why using the netflix app on the console rather than the tv itself...
Timelordsboots
Hi Rooob
thanks for the useful advice. I use an Astro A50 headset which enables me to make use of Dolby Atmos through the headset but not through the Netflix app itself.
Kind Regards Jon
