KD-49XF9005 remote control not working
Movaschi
Hi
my remote (RMF-TX310E) has stop working suddenly. the only feature that works is the mike for voice control.
Any advice on how to solve it?
Many Thanks,
Mario
5 REPLIES 5
LightFoot
Specialist
@Movaschi wrote:
Hi
Many Thanks,
Mario
Hi @Movaschi
The voice control uses Bluetooth so it looks like a problem with IR. Make sure the receiver on the TV is not obscured by anything. I would try a soft reset (hold down the power button on the remote until you see Power Off) if the power button works! If not unplug from the mains and leave off for 5 minutes. Try new batteries in the remote.
Movaschi
LightFoot
Specialist
Hi @Movaschi
If you are still in warranty then I would give Sony UK Support a call. They will send you a new remote or at least take you through the diagnostic steps.
You should be able to download an app, just search for Sony Remote to keep you going.
Replacement or even cheaper compatible remotes are available if you want to test your IR receiver. Amazon are useful because you can immediately return one for a full refund.
PS1978
I’m having the same issue. Did u fix it?
webb01
this seems to be a common fault i also have this issue and sony don't won't to know click here
