KD-55X8509C
Yelnats69
KD-55X8509C
Can anyone tell me the re-set sequence for a KD-55X8509C, it has diamond shaped multi switch, (not 1 or 2 buttons).
in continuously reboots  It will not go past the android logo.
will not load the menu, is the menu/start-up memory on a chip that can be replaced? anyone know the part and cost. (sony is 160 miles round trip from Dymchurch) anyone near me that can fix this.
Also I don't seem to have any coloured LED's on set only white bar light.
what series and year is this model
Set has been great up to now.
stan
4 REPLIES 4
SkyNet404
Specialist
Hey,
Here's how you do a forced reset for the TV, based on the location of the physical buttons on it: https://bit.ly/3EskTwo.
Cheers.
Yelnats69
Thanks tried and did not work.
Ordered a new LG
slivkosi
If you dont have android 6 on your TV there is no reset with buttons on TV.
Sucks.
TV came with android 5.
slivkosi
Why are you putting that as a "solution" if you know that it does not work??????
