KD-55X9005C Not switching on
Mryan84
I have just found out that my tv will not switch on. I mean it switches on but doesn't load anything. I get the Sony logo and then the coloured balls afterwards then the TV switches itself off and goes through the same process all over again. Only way to stop it is to leave it unplugged.
This is only just happened and I've not done anything to have caused this, just returned home switched the tv on.
anyone any ideas as support is closed for the weekend 😞
Hi there
Ive sent you a private message with some instructions.  To be honest, its a bit of a Hail Mary shot though, but worth a try.  If it doesnt, you will need to contact your retailer if under warranty or Sony Support.
