KD-55X9305C remote options
Bishsd
I wish to replace the original remote for Kd55x9305c tv with the RMT-TX300E remote with the YouTube button, will this remote work and will the YouTube function button work??
LightFoot
Specialist
Hi @Bishsd   I would expect that your guess is as good as anybody here in the community. However as a replacement RMT-TX300E is less than £6, why don't you try one and see. I suspect the chances are extremely high for controlling the TV, but very low for launching YouTube. Please come back and update the community with your findings. If you are not in a hurry, you could try Sony Support Consumer Electronics
