KD-55XD7005 remote with mic
tezlewis1988
Hi. I am looking for a remote compatible with this TV with mic so i can use the google asistant as the original doesn't have a mic built in the remote, Is there one that i could buy that is compatible?
profile.country.GR.title
npapanik
tezlewis1988
Thank you for your reply.
Does this definitely work? is it just as simple as pairing once i purchase if so how easy is it to pair?
npapanik
Check this thread:
https://community.sony.co.uk/t5/android-tv/remote-control-rmf-tx200e-for-andriod-2015-model/td-p/230...
I think it will definitely work.
KD-49XF9005
HT-CT390
