KD-55XD8599 random resets
mm0wkj
KD-55XD8599 randomly resets and powers off after last update.
Can be on TV, DVD, Sattelite or built in apps.  Resets without warning with sound cutting out and just shutting down.
Happens every 2-3 days.
Factory rest done twice. No difference.
Running software PKG3.935.0140EUB
Sean_Mc
Moderator
Hi mm0wkj,
Please take a look here for details on how to resolve this issue.
Let me know how you get on?
Thanks,
Sean Mc
mm0wkj
Didnt work.  This isnt the issue.  Its a firmware update problem since the December release.  Didnt do it before that update.
Now had 2 Android system hang ups with 'Google app has stopped' warning on screen.
Is there a download/link for older firmware so I can downgrade until a fix is found?
