KD-55XF9005 Picture distortion
Blumine1818
I'm getting distortion on this TV which only occurs when watching YouTube, Netflix or any similar source.
It does not happen watching Virgin Media or bluray.
The picture occasionally splits in 2 and/or distortion appears at the bottom of the screen.
Either a black bar at the bottom of the screen with a little of the image underneath, or a stripe of distorted colours at the bottom of the screen.
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
Please see the following troubleshooter for help with picture issues here.
Best wishes,
Sean
Blumine1818
Thanks Sean
I rang Sony Support and did a system update.
All has been fine since.
Paul
DarranA
Moderator
Hi Blumine1818,
Glad to hear you got the issue resolved. I will let Sean know.
Regards,
Darran
Blumine1818
Hi
Ironically the problem has returned this evening!
