Hi!
I'm struggling to find the input or a method to cast screen from my Mac on the KD-55XG8505 android TV.
Not sure if it is generally unsupported on this range?
I would really appreciate help!
Thanks,
K.
You should update to Android Pie in order to add airplay support
