KD-55XH8196 Sound outcome
profile.country.DK.title
TheRealKjalarr
Hi I have a KD-55XH8196 TV and I experience sound outcome on the sound for a split second as if the sound resets, I have performed a reset on the TV but the problem continues there are no problems when I use PCM (the problem is only when i run the sound dolby digital / plus output)
TheRealKjalarr
It helped when I connected a LAN cable to the TV, no more outcomes
Piscie
Community Team
Hey @TheRealKjalarr, make sure your TV is updated to the latest version
TheRealKjalarr
