KD-55XH929 low storage
Brickabrack
Hi, i was wondering if you could help me...Last year i brought a Sony KD-55XH929 6BU and now we need more memory so i can download more games/game apps for my son...can anyone recommend any external usb/ or hard drive as when we try to download any more games we just get a message saying "not enough memory"...i appreciate any help or advise in advance.
Eskimosony
No worries, maybe buy the bigger size if they love games. Please mark as Solved👍
Eskimosony
Hi there, I use this, it's fast enough to record TV too. Just plug it in and you are good to go. You can also get larger sizes. It's a lot cheaper than an external SSD and Android games are not as big as say PS5 or XBSX.‌👍
Deal: SanDisk Ultra Fit 128 GB USB 3.1 Flash Drive Up to 130 MB/s Read, Black https://www.amazon.co.uk/dp/B07855LJ99/ref=cm_sw_r_apan_glt_fabc_dl_RXYD3YR3CC9QS8SDGKJ8?_encoding=U...
Brickabrack
Eskimosony
thank you so very much for your help...i will purchase this right away...thanks again and stay safe.
Eskimosony
