Kd49x8005cbu Base width
ChrisCouper
Hi, can anyone tell me the width of the stand on Kd49x8005cbu? Its especially the distance between the rear feet I'm interested in. It needs to sit on a canton DM50 soundbase. Thanks.
Tags (1)
Hi there
I cant find the dimentions either, i believe you require the dimensions of the stand below.  Do you still need this, as ill ask Sony if you do.
ChrisCouper
Ended up buying a Philips 50PUT6400.  Not the perfect solution by any means but should do the job.
Thanks.
