kd55xe9005 wont turn on - Solid Blue Illumination Light
ROF1984
Gents,
Could you please help me out?
When I went to turn my TV (kd55xe9005) on this morning it was non responsive and all I can see is a Solid Blue Illumination LED Light instead of Red, White etc? The Screen is black/ Powered off but the blue LED under the Sony logo appears ( no blinking)
Does anyone know what this code is?
I have tried hard resetting, soft resetting, removing all HDMI and sounbar cables and still at a loss!
Has anyone had this problem before? I only purchased this TV 6 weeks ago and am beginning to think theres a fault!
ROF1984
Gentlemen,
Apologies the model number is kd55xf9005
Not sure if this will make a difference.
Any help is really appreciated 🙂
Sean_Mc
Moderator
Hi there,
I would recommend getting in touch with the support team here who will be able to advise on this further.
Best wishes,
Sean Mc
Hi, I have the same issue, did you get yours sorted? If so how?
