KD55XF8096 USB Hard Drive Recorder....
Eskimosony
So can I just plug a USB flash drive into the KD55XF8096 or does it have to be a dedicated stand alone HDD?
Also does the KD55XF8096 support USB 3?
12 REPLIES 12
rooobb
@57western are you trying to record the skytv? Have you tried via the TV Guide?
57western
Many thanks for he reply. I think the problem might be that all I have is a sky dish and Q box but no TV antenna
as such and no cable. Doing a search for Digital channels gets nothing. I also use the internal router for streaming
services through the internet and I thought I might be able to record things which were transmitted directly to
the screen but it looks like I am wrong on that. Many thanks again for the reply.
rooobb
The skyq box should allow for recording anyhow
