kd55xh8096bu Motionflow
Doddy1975
Hi guys,new to the Sony forum and my first Sony tv in nearly 2 decades !!
The above tv (kd55xh8096bu) has a fantastic picture and great features but I’m not familiar with most of them,especially the motionflow-can anyone recommend the best settings to have ?
regards
mark.
Win_88
Specialist
MotionFlow is a feature that uses the picture processor to insert frames into the content which are generated by and advanced UI, which effectively produces a smoother picture. In general, there are no "best settings" as it's a matter of personal preference.
I'd suggest changing a setting then checking if you like how the picture looks as an effect, or if you can even see any difference
Here's a description for what each setting does:
https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00190409
