KDL-43W755C ethernet issue
kicsibob
Hi!
Noticing my TV ethernet connection keeps dropping and renewing every minute or sooner while standby.  Anyone noticing this?
4 REPLIES 4
Hi
A couple of things to try
  • Reboot TV - Press and hold the power button on remote control for 6-10 seconds
  • Reboot Router
  • Ensure that the ethernet cable is securely plugged in on either end
  • Test on WiFi
  • Try another cable
kicsibob
I have already been tried:
  • reboot TV(and pulled out the power cord) - no changes
  • reboot router(and replaced with another) - no changes
  • try another cable - no changes
  • I don't need wifi, no matter that it is working, cabled connection is needed
If the TV is on, no problem, everything works fine.
It looks like a router syslog:
Spoiler
Oct 3 16:00:05 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:05 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:07 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:20 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:22 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:22 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:23 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:25 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:42 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:42 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:43 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:47 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:56 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:00:56 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:00:58 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:01:01 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:10:11 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:10:11 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:10:14 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:10:17 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:25:19 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:25:19 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:25:20 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:25:22 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:42:29 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:42:29 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:42:31 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:42:33 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:42:50 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:42:50 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:42:51 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:42:53 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:48:08 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
Oct 3 16:48:08 ubnt kernel: ESW: Link Status Changed - Port3 Link Down
Oct 3 16:48:09 ubnt kernel: ESW: Link Status Changed - Port3 Link UP
profile.country.GR.title
MiCal1967
Hi
Seems like an issue that happens also on PCs when both Wired and WiFi are active and Network Cards obtain IP and DNS address automatically. I don't know how to adjust or reset all network settings on Android
Try disabling WiFi Network from Advanced Network Settings and check again.
  • To turn off the built-in wireless LAN
Press the HOME button, then select [Settings] > [Network] > [Advanced settings] > [Built-in Wi-Fi] > [Off].
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/66485/kw/disable%20wireless/rela...
kicsibob
Thanks for the reply! Yes it seems, but the tv was never connected to my wireless network, and the built in wifi was turned off.
