KDL-43W755CBAE Can't find many apps
profile.country.DK.title
MortenTheSonyUser
On my PC, I can see that the app "WD Photos" is available on Google Play, but I cannot find it in Google Play on my TV.
I have a Western Digital external disc with photos connected to my wi-fi. And I would like to show them on my TV.
I hope somebody can help me 🙂
Tags (1)
Hi there
The Google Play Store on the TV does not have the full range of apps that the normal Play Store has.  Sometimes you can 'sideload' some apps.  However if you can stream your Photos via DLNA, why not use the inbuilt 'Album' app or install Kodi instead?
Hi there
MortenTheSonyUser
Thank you once again. The inbuilt 'Album' says that my external disc is empty...
Kodi found the 1000+ pictures at once.
It works fine. Thank you!
Morten
