KE-48A9 - UK TV Apps not staying logged in
aj89zi7q
Hello
The UK TV catch-up services (BBC iPlayer, All4 etc.) accessed via YouView on my Android Bravia do not stay logged in. All apps outside of YouView are fine (eg Netflix). TV firmware is up to date (PKG6.5...). Every day I'm having to go through the laborious process of re-logging in.
Is anyone else having this issue and is there a solution?
Would be great to have these apps supported natively by the TV instead of having to go through YouView...
Bat_Rick
Hi Aj89zi7q,
So you need to sign in each time you use youview, if so did you try to do full factory reset to the TV?
