KE 48A9BU Subtitles
shagnasti
KE 48A9BU Subtitles
How do I disable the the subtitle switch. It defaults to ON
LightFoot
Specialist
Hi @shagnasti
Have you had a look at the Subtitle options under Device Preferences-> Accessibility?
shagnasti
Yes !  Mode = Off. However on selecting Sky News Channel it defaults to On and has to be turn off  every time !
shagnasti
Problem solved.   Factory reset.  Comment: I'm not pleased at having to do this.
