keyboard ,mouse for sony kd-55x8005c ?
leea123
Hi all as the title says i was wondering if there is a reccomended kb and mouse to connect to the tv to be able to use. I noticed that i have speech option on google or orther apps, but my remote does not have that option available , so was just wondering if there is a kb and mouse solution that i can use with my tv. Thank you
rooobb
There is a wide list of USB or Bluetooth option you have with your Android TV, but none will give you the speech option... I would try first to use the official TV&Video sideview app on any Android smartphone/tablet that will give you for free keyboard, mouse and speech capabilties :slight_smile:
http://info.tvsideview.sony.net/en_ww/
PS it works also on iphone/ipad but AFAIK do not support voice speech
Hi there
Many claim on these forums thar they use the Logitech K400.  But as Rooobb said above, it doesnt have a microphone for the speach option.
profile.country.GR.title
MiCal1967
Yes as Quinnicus says, the most common, good and cheap keyboard is Logitech K400+. I think I have seen this and another one as Sony suggestions but cannot find the link again.
The only problems with this specific K400+ is that :
The link is : http://www.sony.net/Products/tv/androidtv/en-gb/
