Mobdro and show box on Android TVs
Ennis86
Hi if someone could help it would be great.. Just got a new Sony android tv love it by the way,, but I'm wanting to download mobdro and showbox. Having a bit of trouble thanks
4 REPLIES 4
Hi there
Googles PlayTV store is different to the main Play Store - as apps must be specifically adapted to TV use.  However some apps can be 'sideloaded' on the TV with a little effort but no guarantees.
Using a web-browser on the TV, goto play.google.com and see if it will install.  If it does, you will need to also install 'sideload launcher' too.
Ennis86
Thanks mate.. I'll give it a try and let you know how I get on 👍🏻
sonipatel
With the help of external devices like Mobdro, chromecast, Kodi & Roku, we can actually play such applications on TVs. It is very easy to download & install [Unsuitable URL removed by moderator] with Chromecast on TVs and enjoy it without any cost
helpers
Hello Dear,
You can just follow this tutorial or article regarding your question.
you can easily used Mobdro App and enjoying lot.
You can watch Live streaming, Tv shows/season and Movies.
*Edit - unsuitable links removed*
Thanks for here.
