MOTIONFLOW
Gally36
MOTIONFLOW
ON MITIONFLOW CUSTOM WHAT ARE THE BEST SETTING FOR CLEANESS AND SMOOTHNESS.  BRAVIA 49XD8088.  THANKS
Hi there
MotionFlow is once again a personal preference.  I personally cannot tell the difference between "Standard" and the other MotionFlow options (like Clear and Smooth), except for picture brightness.
This is taken from another models manual from a previous year:
[Smooth]: Provides smoother picture movement; especially effective for film-based content.
[Standard]: Provides smoother picture movement for standard use.
[Clear]: Reduces motion blur while maintaining brightness for high-speed picture content.
[True Cinema]: Images, such as a movie created in 24 frames per second, are reproduced at the original framerate.
More information:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/65562/
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/134507/
Hi there
More information:
Gally36
THANK YOU ONCE AGAIN FOR YOUR KIND RESPONSE.
You're Welcome :slight_smile:
