Geosarah
Motionflow
On the Sony 49xd8088 what are the best custom setting for MOTIONFLOW.  Thanks
Jecht_Sin
Enthusiast
I use the "Personal" with values 1 and 1. Just because it gives a slightly darker look. Otherwise, for what I am concerned, I can as well turn it off. The only noticeable thing I get out of it, darker tone apart, is the horrible "Soap Opera effect".
Itom86
I have a little problem setting the clearness anything but minimum. Pushing it 1 or above cause high pitch buzzing from the back of the TV (49xd83) while I watching any kind of HDR content. Obviously brightness is set to max.
Can you please confirm, if your TV does the same, or this is a real issue with my TV?
Thank you!
