My KD-49XE8396 TV turns on automatically when my youview box records
A.D.P.
HELP!
The Tv was turning on randomly, i followed some of the fixes on here and it seemed to help, however it does still turn on automatticaly, i think when my youview box records. any suggestions? i cant continue to unplug it when im not using it!
Drewde
Administrator
Can you let me know what fixes helped? Does it only happen when YouView records?
Thanks,
Drew
Mooly01
If the YouView box has configurable HDMI then it may be possible to disable this from the box set up menu's.
