MY5, channel 4 and ITV
tank212
Hi All
Trying to get MY5, Channel 4 and ITV on Apps for my Brava tv KDL-32W705C
Any idea how
Vanilla_
Hello tank212,
I can see that this model is not an Android TV. This means it has a limited number of apps. You can try refreshing the internet content of the TV. If the apps were installed, this means that they're compatible with your TV. If not, this would probably mean that your TV doesn't support these apps.
Best wishes,
Vanilla_
Vanilla_
Hello tank212,
Best wishes,
Vanilla_
royabrown2
Hero
A NowTV Stick is £15, has all these apps, and you don’t even need to subscribe, though the two months Entertainment Pass this can come with will get you a long way through GoT without you having to pay an extra penny.
Buy one and stick it in an unused HDMI port on the TV.
Vanilla_
Hello again,
Yes @royabrown2 , that could be a great workaround for Non-Android TVs when it comes to apps.
Cheers,
Vanilla_
