Naming of Bravia Sync inputs on Android TV
chrgray
TV is a KD65X8509 (android TV), connected to a Sony RHT-G11 sound system. 3 inputs to the RGH-G11, for BlueRay, XB1 (CEC-Tray), and Sky+HD box.
The problem I have is that one of these inputs (player 2 on HDMI4) doesn't display correctly on the INPUT SELECTION option:
Inputs
http://www.flickr.com/photos/tarbat/24042069791/sizes/o/
Nor on the HOME screen:
Home
http://www.flickr.com/photos/tarbat/24016566762/sizes/o/
It's correctly detected in the Bravia Sync device list:
Setup
http://www.flickr.com/photos/tarbat/24098585326/sizes/o/
And also correctly displays if I select Bravia Sync inputs from the ACTION MENU
ACTION
http://www.flickr.com/photos/tarbat/24124679765/sizes/o/
Any ideas how to force the INPUT SELECT and HOME SCREEN to correctly display the Bravia Sync (CEC) name for this input?
EDIT: Possibly connected to item 15 on the "known issues" list, so can this issue be added to that one, thanks.  http://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2047983#M35186
8 REPLIES 8
chrgray
Fixed using the Ireland/EU firmware.
Interesting indeed.  Thank you for confirming this.  Hopefully this replicates over to the long awaited for UK firmware release in Feb.
chrgray
Unfortunately, after a reboot of the TV, the problem is back 😞
Well that was silly then.
Seriously, thats a big bummer really.  :cry:
frogger38
@chrgray @Anonymous Mine also does this, it ocassionaly marks th Sky + HD as 'player_2' other times is OK
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
Risc0n
If you reset your AV Amp to factory defaults it should fix it. This worked for me.
chrgray
So, this does seem to be almost fixed using the EU/Ireland firmware v3.169.  On the old UK version of the firmware, I could NEVER get the inputs to get their CEC labels correctly.  With the v3.169, the inputs do all get their names correctly, but it sometimes takes some time after a re-boot for them to appear.  Once they appear correct, they stay correct.
So, definate progress, which hopefully will carry over to the UK firmware whenever that gets released.
BBonus
I have exactly the same problem with KD-55S8505C in UK. Should I switch to the EU firmware? Thanks.
