Netflix sound keeps cutting out on my sound bar
Philahill
Trying to watch a film on Netflix accessed direct from my 65 inch OLED that I had delivered yesterday. Every 3 minutes or so the Sony sound bar cuts out: if I stop the film then restart then the sound returns. It is really impossible to watch the film. The sound bar is connected via optical cable   Any ideas would be appreciated.
Philahill
So whilst checking the cables I pushed them all in. And....  the problem seems to have gone away !
Thx a lot!
12 REPLIES 12
gunnered
Tried a different optical cable? I guess your sound bar doesn't have hdmi.
Philahill
It does. The installer used the optical link. He was trying to resolve sync issues. Do you think that will fix it?  I get the problem  only in Netflix whether accessing it via the tv or my virgin box
IamNic
Hello @Philahill,
please check if the optical lead is properly plugged in - I once had the same issue with my TV and it was simply not connected properly.
- Nic
Philahill
All seems ok.  I think I need to change it back to hdmi from Optical. Both the hdmi cable and the optical cable are plugged in. Just got to find out how to do it.
Philahill
Thx a lot!
gunnered
That is so typical of optical cables, especially the cheaper ones. They never seem comfortable in their socket!
IamNic
Hello @Philahill,
glad to hear it now works :thumbsup:
- Nic
Philahill
Thanks. Not helped by crap John Lewis installers. They even plugged my headphones into the audio input....
Philahill
So.... whilst it is better I now have the problem that the first word of sentences keeps being dropped off, almost like it takes time to restart even after a very short gap. I have a feeling I need a better optical cable. Any ideas?
