netflix
sullie12
netflix
hi i've just recently purchased a sony kd49xg8396 tv on the remote it has a netflix app button which works ok but when we want exit the netflix app it just doesn't work the same we have to go through the settings is there a simplier way of getting it back to the tv ? we had an lg smart tv before on the remote it had the netflix app and an exit just below just press exit and went back to the tv , so can any gve me easier way to exit netflix
LightFoot
Specialist
Hi @sullie12
What happens when you press the TV button? If it doesn’t go back to TV you can change its function in the settings.
httpswww.sony.co.ukelectronicssupportresmanuals47481ee9d7e96d2562c6509beb1a99f1537347484301M.pdf.pnghttpswww.sony.co.ukelectronicssupportresmanuals47481ee9d7e96d2562c6509beb1a99f1537347484301M.pdf.png
LightFoot
Specialist
Hi @sullie12
