No WiFi connection with sky q box home button and sync menu button not working
Rachael888
Hi
due to work at home the electrics were turned off - since then my Sony Bravia now has lost its WiFi connection - the sky q box appears to be working fine but both the sync menu and home button are not working.
any help would be really appreciated
Pascale_F
Moderator
Hi Rachael,
Welcome to the Community.
You could try contacting
Sony Support about this.
Thanks,
Pascale
Rachael888
Thank you I did a reset in the end and the buttons are all back working!
Sent from my iPhone
Sean_Mc
Moderator
Great!
