Nougat update sound issue
johbaker6
Tv: KD-43X8309C
Updated firmware: Android Nougat update (5.381)
HDMI ARC connection to external Amplifier with 5.1 speakers.
TV Speakers left on 0 (zero)
Since latest update switching from TV to Android TV (home) screen no sound is output from apps on ARC HDMI.  If I turn tv speak up to 1 and then back to 0 sound output to ARC HDMI channel works again.
Never previously had this issue and all settings remain the same before and after firmware upgrade.
Is this a known bug?
jumpsuit
Hi @johbaker6 and welcome to the Community :slight_smile:
I don't believe members have reported this before, it may be worth you
contacting Support on +44 (0) 2073652810 to check.
johbaker6
No longer have that tv. Due to my son having and acident with a toy we now have a XG83 2019 series tv. In setting up I did have problems getting sound through ARC so run direct via optical now.  My amp is several year old so it could be a limitation of the system and while tvs are updated the amp isn't and so at some point something might have been devolved.
