HI, CAN SOMEONE TELL ME WHAT CABLE JS BEST TO CONNECT AN LG SOUNDBAR TO A SONy 49XD8088. THANKS
Solved! Go to Solution.
Hi there
As Marino says above, it depends upon which connections you have. However, If you can use HDMI (via HDMI-ARC Port) then it is always best to. Reasons are:
it also depends on the Soundbar connections ... Soundbar's models?
Manolo
Hi there
The SOUNDBAR is an lg from an earlier to set up. Thanks
Hi there
Just a little bit of friendly advice - on the internet, when posting something in ALL CAPITALS, it is considered as shouting and hence is rude (unless you mean it of course)
Also, I know you have mentioned it is an LG Soundbar, but its like asking a mechanic for advice on which tires your need on your car and you only tell them its a Ford. Its some help, but model numbers help the most.
Anyway, see my reply above - best to use HDMI when able to.
PLEASE ACCEPT MY APOLOGIES, IM VISUALLY IMPAIRED AND USE CAPS AS EASIER TO READ, I GET MY PARTNER TO READ AN WRITE SOMETIMES.
I HAVE NOW CONNECTED THE SOUNDBAR VIA HDMI VIA ARC AND IT WORKS FINE. THANK YOU AND SORRY AGAIN.
You're welcome. I understand.
If we can help on the forums for any issues you have, we will do our best.
THANK YOU FOR YOUR HELP
