OTA Update broken my TV KD-55XF8096
Eskimosony
Well, everytime there's an android android  update my TV gets slower...this time however it's lost internet connection and refuses to switch to HDMI input when I switch on my Xbox. I also can't set the devices name as it  just won't accept what I choose. It's a KD-55XF8096 and it's getting worse.
12 REPLIES 12
Eskimosony
I will do that this afternoon and report back. It will just take me an hour to get all the apps back and set up my Bluetooth headphones.
Eskimosony
Ok have done a Factory Reset...wow it was like switching on a new TV, the setup is all Android and certainly different to how I remember it back in 2018....HOWEVER It has not fixed the problem. Switching the TV on using my XBox in the morning still causes it to hang in no man's land. Or more correctly, it switched the TV on to whatever TV channel I switched it off...then after about 10-20 seconds it tries to switch to the HDMI2 input and just goes to a black screen. Stupidly, if I switch off the TV and then try it again it works...meaning that during the night something happens... i.e. after some time, I dont know if it's minutes or hours the problem occurs. It was running perfectly before the Firmware update...like I said everytime they break something.
Win_88
Specialist
Try going to the channel setup section of the settings and disable Update Guide in standby as well as Interactive Applications
