Pairing problems bluetooth headphones
Green-Lantern
Hello. I'm trying to pair a Sony bluetooth headset with a new Bravia
KD-55XD8505B Android TV. It doesn't work. Would not pair. I got the headset into pairing mode, went to the bluetooth menu in the system settings and hit "add new device". I am nearly certain I didn't do anything wrong. I googled this and found a few disconcerting posts on Quora to the effect that Sony Android TVs don't support pairing headsets without seperate bluetooth transmitters. I hope I read that incorrectly! Does anyone have any advice or futher info? Thanks. GL
10 REPLIES 10
Hi there
How ironic - two same posts within a few hours of each other :slight_smile:
See:
https://community.sony.co.uk/t5/android-tv/bluetooth-headphones-amp-sony-kd-49x8309c/m-p/2257397
waseem.ahmad
I have tried many different makes and models of Bluetooth headphone in last more than years  to pair with my Sony Android TV but never been able to pair Bluetooth headphones If any one in the world know of any compatible Bluetooth headphones  with my
SONY KD-55X8509C TV or any other way to hear sound from a Bluetooth headphones
LightFoot
Specialist
Hi @waseem.ahmad
The KD-55X8509C does not have the A2DP profile support required to connect Bluetooth headphones. Unfortunately this means that there is no compatible Bluetooth headphones that will work without the A2DP profile.
Marino.Manolo
Genius
@waseem.ahmad
For the models since 2016 there is a workaround, before a Pairing you need to install the Bluetooth Pair Application and then try pairing (I can not guarantee that it will work for your 2015's TV). Bluetooth Pair can not find it in the Play Store, you need to search the Internet for the installation of the Apps (APK), then transfer it to the TV via a USB memory and install it with a File Manager (if you do not have one install it from the Play Store ). You have to enable the installation from "Unknown sources" on the TV, find a MENU item with this name.
Manolo
Joseant3169
After the fail pairing my bluetooth headphones with 55-XD8577 TV, I bought the next bluetooth adapter.
https://www.amazon.es/gp/product/B07C2Q79BY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It has an optical conexión and the optical wire is incluided, so the sound quality is great and It works very well.
profile.country.US.title
Daviy7
Bluetooth pair application confirmed working on xbr 800E.
nredin
I can confirm Bluetooth Pair application (downloaded here https://tinyurl.com/y6nrjr6d) did solve the problem and I was able to finally pair my bluetooth headphones to Sony Bravia 55XE8096.
henrikkhach
It worked and succeeded to add my OnePlus Bullets Wireless 2 headphones but unfortunately there is no sound.
sam_2020
