Picture profiles AG9
WhiteDear
I have been playing with the different picture profiles on my AG9 and i have some questions i hope can be explained to me.
My impression of picture profiles were that they basically were the same. They just had different settings. But i can set the settings for the "Vivid" profile and the "Standard" profile to be exactly the same and the "Vivid" profile still has a slight dim compared to "Standard".
Same thing with "Dolby Vision Bright" and "Dolby Vision Dark". Same settings, but "dark" is actually darker.
I am quite sure the settings are the same, so i was wondering if picture profiles have som hardcoded hidden settings do differentiate them from each other?
Tags (2)
Pascale_F
Moderator
Hi again, Whitedear,
I will see what I can find out about this too.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi WhiteDear,
I'm sure that the engineers programmed the mode to have different effect, that can't be achieved by manually adjusting the settings.
Cheers,
The_Black_Rose
