Power cable for xr55a84j
Graham1-00
Require new power cable
For my TV.
XR55A84J
LightFoot
Specialist
Hi @Graham1-00
I am going to guess that it is a C17 power cord from Amazon (you can always return it if it does not fit).
Here is a photo of my A95K ...
LightFoot
Specialist
Hi @Graham1-00   Can you take a picture of the socket. Is it a simple lead or is a power brick involved.
Graham1-00
HI it's a 2 pin the shape is like the 3 pin
No brick involved
LightFoot
Specialist
Hi @Graham1-00
