I have my xe55 connected via wifi. Both Disney and Amazon Prime do not work as it states an internet connection issue. whereas Netlix is working fine. what do I do?
Solved! Go to Solution.
Thank you. Bizarre issue, I found another thread with this. I feel for all those that don't use this community, I'd have tried everything, router, modem, everything. I feel Sony should push an update to fix the time issue asap.
It depends on how the date/time setting is on your tv. If it is automatically set via network or broadband, it should get it from there
