Programme Recording ? TV has to be on & can you record halfway through?
Prior20
So setup everything yesterday and tried a couple things
record a programme that had already started - Resulted in a fail, saying timeshift or programme had already started (funny as timeshift isnt supported on this set anyway)
Record a program when the TV is on standby - Resulted in a failure to detect storage fail.
is this normal?
Sean_Mc
Moderator
HI there,
So I can try to help, can you let me know which product you are having issues with?
Cheers,
Sean Mc
