"no network devivces found" when using Album App
profile.country.IE.title
Anna.dynan
We recently purchased a Sony Bravia TV. When we put in a USB memory stick formatted as FAT32 it does bring up the option to Browse the USB. Instead it says "no network devivces found". The memory stick with the photos is accesible on the ES File explorer App but we cant do a slide show etc. I also tried to format the USB as NTFS but no joy. For some reason the Album App is not recognising the memory stick. I looked at the permssssion on the app but cant see anyhing unusual. I also cleared the cache on the Album App.
Has anyone come accross this issue ?
Anna
Tags (2)
Sean_Mc
Moderator
Hi Anna,
Can you let me know the model number of your TV?
Cheers,
Sean Mc
Anna.dynan
Hi Sean
It is sony 55Xe9305b U
We ate now using the explorer fs app but we can't do a slide show with this. Memory sticks are accessible using this app
Anna
