recently bought a KD55A8 but cannot get sound on the internet
salmon45
Jewers
If you mean you cannot get sound on apps, turn TV off via remote control and unplug TV from the mains for ten minutes.  Then plug back in and switch on with remote.  This happened to me after a software update and this procedure has fixed it.
salmon45
All good now, thanks for the advice
