The message you are trying to access is permanently deleted.
I have an Remote RM-ANU032.
Do you have a manual for this?
Is this remote still available?
Hi @hardensony
I can see that this remote is from circa 2008 but plenty of compatibles still available from Amazon. I very much doubt that the original is still available.
As far as manuals available, I suspect you will have to go to the original AV Systems that used this remote. For example RHT-G1550
