Removal of media servers from kdl-43w756c memory?
How do I delete unwanted media servers from appearing in the devices section on the TV?
I have looked at threads for older Bravia TVs and they indicate that this can be done via the home network setup route but I can't find any options to delete when I get to a level where the the media servers are listed?
This is driving me insane as even a factory reset didn't get rid of the server even though the server is no longer active as is deleted from my computer and otherwise removed from the network.
Hi there
Goto Settings > Network > Home Network Setup > Remote Device/Renderer > Renderer Access Control > Custom Settings
Believe you can delete from their
