Screen Mirroring input is failing
Hey,
Every time I try to connect my android device, any, with my android TV (KD-70XF83) the TV automaticaly disconnects from the WiFi so the syncronisation between my device and the TV fails. So I need to manually reconnect the TV to WiFi and try again. I'm quiet sure this is a hardware problem, does anyone experienced the same thing?
6 REPLIES 6
Mick_D
Moderator
Hi @Pako_zavala
This problem rings a bell; I'm sure it was brought up in an earlier thread. I'll ask around and hopefully get back to you.
Mick
batee5
Specialist
Hi Pako_zavala,
Welcome to our community!
It seems a bit odd that the connection to Wi-Fi only cuts out when screen mirroring is activated. Especially that there are a number of reasons why this could be happening.
I'd say start with making sure your TV is running the latest firmware version . You use this link to check.
I'd also recommend checking the channel on which your router works because if it randomly changes channels or fixed to one that's not supported by the TV it could affect the connectivity. You'll find more information on that here.
Let us know if that helped to resolve the issue or not.
Cheers,
Batee5
profile.country.BG.title
Stoyan78
Lately i have the same problem.
When i open screen mirroring  app the wifi automatically turn off and i need to turn on the wifi from the menu.
my tv is up to date.
SkyNet404
Specialist
Hey @Stoyan78,
What's your TV model and the software version installed on it? as this thread is really old, and fixes for this issue has been implemented as far as I know.
Cheers.
Stoyan78
KD-43XG8196 and latest version of android 9
SkyNet404
Specialist
Try to check these, hopefully they help: https://bit.ly/2YwzhDg & https://bit.ly/3Hd3CIi.
