ScreenRecording - finally works on Oreo!
khallergard
Screen recording has been a disappointment, till now.  Tried 5 apps:  DU Recorder and AZ Screen Recorder work, though without their overlay menus.
 Vlog: https://youtu.be/7283xx7FoUg  Blog: https://tinyurl.com/y4km97xr
Mobizen, Recordable and ScreenRecorder 5+ (by NLL) do not work.
Have not found anywhere to allow permission to "Draw over other apps"
Tags (1)
Pascale_F
Moderator
Hi khallergard,
Thanks for this. Did you need help with anything?
Thanks,
Pascale
khallergard
Thank you Pascale,
Howto enable permission to "Draw over other apps"?   (this was the main issue I encountered, affecting most of the apps in one way or another).
Thanks,
khallergard
